Just sharing what I found regarding a solution for the slightly oversize antenna hole on the fender that some of us have..
I believe my fender hole to be factory ( my 74 2.0 has proven to be 95% undisturbed by previous owner alterations/replacements ect. and I have read a thread here of others having a simular issue.) and the Hirschaman antenna that fit well I took of it I believe was also factory and was uniquely different in some ways to the New Hirschman, been awhile since removal and was ignorant 3 years ago, but the newer Hirschmann do not fit nicely and barely toe in mounting if it all in certain positions.
I have the same slightly oversized hole (*there is a thread on this somewhere on this site) the the New Hirschmann antenna available everywhere just does not or barely fills enough to hang on with and decent mounting security..
My intial solution that has worked was to get a larger base from a cheap vw? antenna and use that in place of the Hirschmann base but still use the HIrschamann antenna istself.. Woodys Custom Shop (Antenna Collector and Seller.) learned me the differences and supplied me an antenna with the bigger base but it is an el cheapo version of a vw antenna, so I combined the 2..
Then I just recenly found Poddig Antenna's German Made High Quality available from a seller on SambaVW and same seller on ebay; in fact some are "museum?" collection Antenna like a rare Bosch red tip or Hirschmann..
link; air-cooled museum boutique $100 euros?
http://www.aircooled-museum.com/boutique-2...ig-antenna.html
Picture of what the seller has and link, there are 2 sizes available 100cm &
150 cm and the price is only $20, ..
link;
http://www.thesamba.com/vw/classifieds/detail.php?id=1013263
More importantly the base (mounting portion) is a good fit, without looking oversized or unfitting, comming in at 36mm clamping area..
I bought one and it took 2 weeks to get but damn it is a quality piece.
They are or seems to be on the long side when fully extended but if you read up on why car antenna's are the length they are; you will see why they are the length the Poddig chose and why the shorter one is 2/3 the length of the longer on is..
