Full Version: push rod tube seals
914 shifter
"You can bore the heads for larger tubes and solve the issue, else you'll have to have the correct seals which are NLA as far as I know.. I'd use the old seals and seal them up with my teflon sealant.." this a reply from the classic thread "push rod tube seals."one of my tubes is leaking at the head original 1.7.i was going to order some seals but it appears they are nla? hissyfit.gif
G e o r g e
QUOTE(914 shifter @ Jan 29 2011, 09:15 PM) *
http://www.aircooledtechnology.com/store/p...=301&page=1inner seals
bandjoey
Many sources. Auto Atl. - Pelican - and others on this site.
G e o r g e
more for sale
wasn't trying to suggest one spot, just that they are available
detoxcowboy
they are all over the place, always check vw sites too.. I have never seen them nla, plus them come in engine gasket sets, i given away sets.. what do you do with them all.. plus there is always someone here on this site whom knows somewhere or has them personally.. drunk.gif
Dave_Darling
Just note that the early 1.7 heads have smaller bores for the pushrod tubes than most heads do. AFAIK, you can get the silicone seals for those but the "usual suspects" don't carry Viton seals for the smaller bores.
--DD
tat2dphreak
QUOTE(bandjoey @ Jan 29 2011, 11:52 PM) *
Pelican, I'll bet even Eric Shea can get those pieces to you... only buy Viton though!
