QUOTE(underthetire @ Jan 31 2011, 05:57 PM)
And the job is much easier if you pull the tire, unless your on a lift. As the capn said, just unbolt the top one from the engine side, the starter flange will hold the head of the bolt for you. Then pull the bottom nut. Pops right off. After all the "lifetime" flaps starters I can now do one in less than 15 minutes.
To undo the upper bolt means that I first have to remove the engine cover ( 022 119 517 R ) in the motor compartment to get to the starter?
