check "Eagle Day," "WayTek Wire,":
M/F connectors with housings:
http://www.eagleday.com/blco.htmlblade terminals w/o housings:
http://www.eagleday.com/bladeterminals.html (I get the male terminals here, females at waytek wire--see below)
You have to be a little careful here as some of Eagle Day's parts have the latches while others don't . . . .
F terminals at waytek wire at
http://order.waytekwire.com/productdetail2...AY%20CONNECTOR/ (search part number 31073 for female teminal--but I've been unable to find the male terminal here, sometimes get the males (PN 3-1901)
at eagle day even though they are a little narrow (5mm vs .25 inch/6.3mm).
PN for female terminal at Susquahana/www.rallylights.com is HL87272 (Hella part).
Depending on how badly you need them, your local Volvo dealer may also have a good assortment in "bench stock." I'll try to post a pic with Volvo PNs later today--they tend to be a little more expensive though, up to about $1 each . . . .
