OK, my car had a redundant decel valve, and an air elbow (the rubber tube between the air flow meter and throttle body) with cracks large enough to cause air leaks. I ordered a new elbow from Auto Atlanta, along with new upper and lower hose connectors (my old elbow used a small upper hose connector and a large lower connector). The replacement elbow uses the same size fittings (large; about 20mm) in both positions, and although they said they had them, they were not included with my order.
My hose connectors were modified to the point that they are not recognizable, and one of them had a large diameter 6mm washer brazed inside to act as a restrictor. Now, my question. Do any of you have a pair of the hose connectors, and can you sell them to me or tell me if either/both use an internal restrictor?
FYI; the PET shows a different part number for the two connectors, but something must have changed over time, and Auto Atlanta told me that the upper and lower connectors are the same. And they have no additional info to help me.
Any help/advice will be greatly appreciated.
