Been there got the t-shirt
Had great fun doing all this a few years ago.
I used Eaton M45 blower, first off on turbo spec dells on a 2.4litre, just to design the blower mount and pulley system. Pulled 190hp @ 5500 and 192ftlb.
Lessons learnt at this stage:
Poly V belt slips
By Pass valve is essential
6psi was max the little M45 could give out
charge temp was too high to be acceptable
Car was drivable but very noisy supercharger and I felt there was a lot more I could get out of the solution if I optimised things, hence came phase 2...
Phase 2
Fully programmable ECU and FI
Chargecooler
M62 blower (i.e. bigger)
Toothed belt
1 3/4 exhaust was required
Results
14psi boost, charge temps under control now, no belt slippage. The throttle body is above the blower the injectors are below. This prevents any condensating (pooling) of the fuel if it passed thru the charger. It also meant the blower was kept quiter as it was behind the throttle body.
Problems
Only main problem found was the heads didn't seal properly to the 103mm barrels. So I fixed this by cutting grooves into the head and opposite profile into the tops of the barrel. This fixed the issue.
5000+ miles later all is good - although probably going to get round to selling the engine as need to start downgrading the engine in time for son to inherit the car
