Gint posted a few pictures for me, Thanks Gint
I know I should include pictures, but I can't get that to work for me, so if you are interested, PM me and I'll get some to you.
Well, my back isn't getting any better. I only was able to drive the car about 100 miles last year. So I'm thinking it may be time to let someone else finish with this car. $7500.00 firm with extras, books, parts, etc.
Car came from Camp 914 in 2005, before that, central valley Calif. Good thing is very little in the way of rust issues. Bad is sun dried window seals and bad paint. It has a couple of scratches and small dents, otherwise body work will be minimal.
Here are some of the things I have gotten done.
Extras;
SSEX's with triad exhaust- no heat hooked up, but I have all of the right parts to get that done.
Renn-shift and all new bushings- shifts great.
Jim West fog light flasher
Jim West fuse panel
Momo steering wheel
New wheel bearings all the way around
New brake pads all the way around
Rebuilt rear calipers by Eric Shea
New bushings in trailing arms by Eric Shea
New seals in oil cooler
New clutch ( 6 spring sachs) pressure plate and throwout bearing
I dropped the engine, removed the tin and cleaned the engine really good and painted the tin. Made a new ignition harness due to brittle wires.
Lots of other stuff done, but still needs a few things worked out.
Car starts and runs great and strong.
If you would like more pics, PM me and I'll get back to you.
Tom
