Guys, need some help. PO gave me a red valet key. This key works the ignition with no problem so I purchased an OEM black Porsche blank and had it cut to match. It now also works the ignition fine (so the cut was good).
When I insert the black key in the glovebox or rear trunk lock, it will not turn at all, ok to assume a re-key on these locks?
When I insert the red or black keys in the door locks, they turn about 45 degrees to the right but with a strong feel of resistance. Is this normal behavior, assuming that the tumbler and lock mechanism need a good cleaning and lube or do these need a re-key too? e.g. Should the door locks turn zero if the key was wrong? The doors do not seem to be locking right, and I don't want to force the key without understanding normal function.
One last question, when you lock the car doors, do you need to hold the handle up when shutting the door?
Thanks
