Hello,
This started with a problem I had with, what I believe to be a stock 1.7 FI engine.
In a prior thread I diagnosed a FI problem which I thought was caused by a malfunctioning Manifold Pressure Sensor, so I replaced the unit with a tested functioning one. This did not solve the problem. As it turns out the problem was oil on the distributer FI contacts, (I found the repair in the factory repair manuals but discounted it, sometimes I just don't learn).
I left the MPS that I replaced in the car since it was running.
After a few tankfuls of fuel I noticed the mileage was not so great, about 21mpg, although I do push the car hard, I have had much better mileage.
I decided to pull the MPS and put my old one back in, also the sensor was a bit to close to the fuel rail and I wanted to adjust the distance.
Looking at my "original" MPS I was very surprised, the numbers on the body where the "same" and "different" from the PBAnders info on Rennlist!
See the photo below.
Anders indicates the the correct MPS for a 1.7 is Bosch # 0 280 100 049 and the VW # 022 906 051E as you can see the unit has the 049 Bosch number above the VW 051 number but the last letter is a C with an X engraved over it and an E engraved to the right of the X'ed out C!
In addition I can say that the unit was tampered with.
The rivets have been removed and the body tapped and screws used to hold the unit together. Also the center of the of the epoxy plug has been drilled and resealed, it seems with the same epoxy.
I have owned the car for 29 years, I have replaced a few FI hoses and a rubber boot or two, and leaky fuel injectors, but that is about it.
So the questions I am starting with, was this a "type O" at the Bosch factory and a change in production or is this a remanufactured unit, I suspect the MPS was still available before 1983 and this could have been a hodgepodge of different parts to make a functioning unit?
I will also update this post with any changes in fuel mileage.
Thanks for looking.
Mike
