QUOTE(gms @ Feb 15 2011, 06:18 PM)
QUOTE(twash @ Feb 15 2011, 10:25 AM)
what type of cable pull set up 0n #12, #11 used a later 911 box with unmachine push clutch parts adapted to a pull set up, this was due to regular 914-6 boxes not available. picture of the early box is shown in the factory owners manual.
Nope my is standard
What gears did #11 have?
as the #11 car had vw factory race support , upon inspection gears in the transmission are A,F.M,S, X WITH 904 MAIN SHAFT WITH ZF LIMITED SLIP. the gears were set up to match the power curve of the 906 engine twin engine.
On the other hand the gt gear box of #1543 has a,e,j,q,w with 904 main shaft and zf limited slip (80%) for its rally use
