mrbubblehead
Feb 15 2011, 06:25 PM
after a couple of hours, i give up.
heres my problem, my turn signal idiot light quit working. if i pull the emergency flasher switch, the switch flashes, the idiot light flashes along with all of the outside lamps.
if i turn the turn signal switch to the right- i get one flash from the idiot light and thats it....the relay is ticking and both of the front and rear outside lamps flash.
same thing with the left side, 1 flash from the idiot light then it goes out, but the relay ticks away as well as the left outside lamps.
i need to mention that the relay ticks at its normal pace. when the turn signals are on as well as the emergency flashers. i have replaced all of the turn signal lamps as well as the idiot lamp with the proper lamps. and cleaned all the sockets with emery cloth.
what kills me is the damn idiot light flashes when the E flasher switch is pulled. so i know that it is working. also all of the turn signals work and flash. just not the idiot light.
any ideas befor i plunk down 55 bucks for a new flasher relay?
jim_hoyland
Feb 15 2011, 07:00 PM
See if this helps:
http://www.914world.com/bbs2/index.php?sho...47236&st=10I've used the information to solve several issues and do a mod.
Feb 15 2011, 07:18 PM
Just curious, with the engine running, after the one flash, if you rev the engine above 2500rpm (or more), does it start to flash correctly???
mrbubblehead
Feb 15 2011, 07:30 PM
QUOTE(SirAndy @ Feb 15 2011, 05:18 PM)
negative. rpm has no effect.
mrbubblehead
Feb 15 2011, 07:31 PM
QUOTE(jim_hoyland @ Feb 15 2011, 05:00 PM)
See if this helps:
thanks jim. BOOKMARKED!
mrbubblehead
Feb 15 2011, 07:37 PM
from what i can tell, the secondary relay is not sensing the load of the 2 turn signal lamps. but it does sense it with the 4 E flasher lamps. hummm?
i guess i could add a nother lamp in the turn signal circuit and see if it draws enuff current to trigger the secondary relay.
either way, it looks like a new combo relay is in order. damn.
Mike Bellis
Feb 15 2011, 07:38 PM
You have a bad relay based on your description. The flasher relay is actually two relays in one case. The first relay flashes the signal lamps. The second relay flashes the dash lamp. There is also a small circuit board inside the case.
Your relay is bad. You can continue to use it until it fails compltetly but you will end up leaving them on all the time.
mrbubblehead
Feb 15 2011, 07:58 PM
QUOTE(kg6dxn @ Feb 15 2011, 05:38 PM)
ya i figured.....i just ordered one. i had a choice between, a chinese one or og hella.
i got the hella.
John
Feb 15 2011, 08:06 PM
Your relay is bad. You can continue to use it until it fails completely but you will end up leaving them on all the time.
+1
That's the old sign of a bad flasher relay.....
mrbubblehead
Feb 15 2011, 08:38 PM
ok, now here is something weird. with the key off, if i turn the turn signal on, left or right, my running lights come on.
Feb 15 2011, 08:47 PM
QUOTE(mrbubblehead @ Feb 15 2011, 06:38 PM)
Not weird at all. That's how the parking lights work on all European cars ...
mrbubblehead
Feb 15 2011, 09:16 PM
QUOTE(SirAndy @ Feb 15 2011, 06:47 PM)
no kidding? im gonna go check my vw's right now.
i thought something jacked up
hehe
mrbubblehead
Feb 17 2011, 07:53 PM
SORTED! plugged a new relay in and waalaa. the idiot light is flashing. cross another item off the list.
