QUOTE(underthetire @ Feb 16 2011, 04:26 PM)
Think I know where you were going with t his thread. If you don't have an indexer on a mill, you need to trig out each hole for X/Y coordinates, or use this. (all of our machines have it built in, so does your mach3 )
http://www.doov.com/cgi-bin/bolthole.cgiI drew them up in bobcad... and I switched over to the linux box with EMC2 on it. It let the CSOB in me buy more stepper drivers instead of more software.
I did a circle array every 72 degrees; now to get the back lash out of my rotary table again. I had it *perfect*, and then had to disassemble it for the stepper motor mounts.
And thank you for the link, I have it bookmarked now.
(on second thought, I don't really need the rotary table, I have the x/y table pretty dialed in and I can adjust the 'round' on the lathe when it shows up)
