falconfp2001
Feb 16 2011, 05:28 PM
Just pulled a 1.7 and was wondering what I can reuse for a 2.0 build I'm planning.
The engine tins are nice and just need cleaning and repainting but are they usable on a 2.0?
I'd also like to know what other parts are usable or interchangeable?
Thanks
Frank
bdstone914
Feb 16 2011, 05:42 PM
You cant use the same top tin on the 2.0 without some interesting cutting. Ive seen it done but just buy the right top tins. Spark plug angle is different, meaning your holes wouldnt line up with your spark plugs at all.
TheCabinetmaker
Feb 16 2011, 06:50 PM
I think the rest of the tins are the same.
gothspeed
Feb 16 2011, 08:41 PM
It is my understanding that tins are the same except for the cylinder top tins. You would only need 2.0 tins, if you are using 914 2.0 heads on your motor. I will be making a printable 'template' so anyone can hole saw their 1.7 tin to work with 914 2.0 heads.
Dave_Darling
Feb 16 2011, 10:15 PM
The lower-left tin is different between side-shifters and tail-shifters. But it doesn't sound like you'll need to worry about that.
I think 72 rear vertical tins have an extra hole in the left side, for the warm-air intake setup. But that can be ignored pretty safely.
--DD
