Heyguys, I'm looking for this and I've tried a few things on the search function, but I can't seam to find the proper values for the valves on this 2.7, any knowledge for a young dumb rookie?
SLITS
Feb 16 2011, 06:42 PM
0.004" cold for both.
Cap'n Krusty
Feb 16 2011, 06:43 PM
Valve clearances for 911 engines with adjustable valve lash are .004". They need to be right on the money, especially for the earlier engines.
The Cap'n
RiqueMar
QUOTE(RiqueMar @ Feb 16 2011, 04:34 PM)
The Cap'n
Awesome guys, thanks for the help!I'm glad to see the 'Pro's' are on right now!
SLITS
Feb 16 2011, 07:12 PM
make sure you get the tool with spare blades ... makes it much easier (kinda)!
Cap'n Krusty
Feb 16 2011, 07:33 PM
Wayne's "911 Valve Adjustment Made Easy" shows you the hard way, but that's OK. ALWAYS adjust the valves BEFORE you remove the spark plugs. Too easy for a piece of carbon to be dislodged and fall into the opening for the exhaust valve, making your adjustment way off.
You can use my easy valve adjustment method (which can be found in the Classic Threads forum). Rock one valve all the way open, adjust the opposite valve. Piece o'cake. In the car, you use a starter button, out of the car, you use a 19mm (3/4") box wrench on the crankshaft pulley.
Sounds like a lot more work (especially with the engine installed in a 911, much less a 914 where access is severely compromised), and I doubt it's more accurate than my technique.
The Cap'n
