Anybody out there using the Renegade Subie conversion also using the JWest Shifter Linkage setup? I already have the Rennshift setup, but continue to have bushing issues causing sloppy shifting apparently because the fabricated shifter bar (necessary to clear the engine) is not exactly right. I figured if I was going to have to adjust the shifter bar (cut it up) again I might want to go with a better setup.
Ed
