QUOTE(McMark @ Feb 16 2011, 10:34 PM)
Short Answer: Yes
Long Answer: You need to vent your crankcase. And to avoid messes and environmental impacts, you should filter your crankcase ventilation. The best solution is to filter the vapors, drip drain it back into the case, and connect the filtered vapor to the intake so that any missed particles can be burned in combustion.
Do you have any pictures of the set u I have dual carbs.
