QUOTE(Jeffs9146 @ Feb 17 2011, 09:25 PM)
First check that the fuel pump is priming! Turn the key on and off, you should hear the pump buzz then click off!
If this is not happening you should check the fuel pump fuse on the relay board in the engine compartment. Then check that the pump is getting 12v when the key is turned on!
Dave, thanks for the tips - just hadnt been warm enough out til this week to check those things. I had suspected it was a fuel problem since I didnt smell gas after trying to turn it over....but this morning I started with the injectors and got nothing so as I thought, that was the culprit.
Thank you Jeff....those little noises you hear every time and are so easily overlooked when you dont hear them....yes, in fact after checking the injectors once and getting nothing I remembered! Keyed it off then back on and BINGO no fuel pump priming noise. So, there I was undoing the screw to check the relay board in the engine compartment....staring at the battery whilst turning the screw and just happened to notice one of the little power wires to the battery post had been pulled out of the crimp connector probably when I was connecting the battery charger clamp last time.
She's running fine now.
Thanks guys.
