If your transmission is good, and you've replaced ALL of the bushings, you just may need to adjust the shifter in the center console. Remove the plate, and I think it takes a 10mm socket?? Isn't everything a 10 or 13?
Loosen it up then shift to a gear and when you find a gear, tighten it back up.
