QUOTE(Jesse @ Feb 19 2011, 10:43 AM)
It's a good practice to always check the oil before starting any old engine, (car, boat, or yard equipment) . when i found the gas in the oil i dropped the oil out and left the drain out while pouring fresh oil in to flush the gas out, let it sit overnight with the plug out, the next day put the plug back in and filled with oil, rolled the engine over 2 times then drained her again. let that drain relly good then refill as if a normal oil change, (dont forget to change the filter). I ran her for about 2hrs around town here, no smoke or prefomance problems. 2 weeks later we went to MUSR the only problem i had up there was rich mixture (we are at sea level here and 1300ft at MUSR) she has run like a dream lately been driving her to work 2x per week 85mi round trip all winter with no problems.
GOOD LUCK
Thanks for the step-by-step--that's what I'll do. Agree with always checking the oil prior to starting too. I thought "I need to check the oil" at least twice, but after fixing a couple of other issues I guess I forgot about the oil.
"Target fixation"--at least that's what we used to call it. I must be getting old(er).
Well, tomorrow is another day.
Thanks again Jesse--I appreciate it.
Steve A-
