MikeSpraggi
Feb 22 2011, 12:45 AM
I hear some have problems with the top of the Koni yellow shocks hitting the inside of the front hood, not allowing it to fully close. I also thought I have seen photos of at least one hood that had little humps or holes in the hood to allow the adjuster screw to clear for closing. Anyways, what is normally done when the clearance issue is encountered without having to modify the hood? I have 72-73 911 struts (for Koni) and a fiberglass hood. Thanks.
SLITS
Feb 22 2011, 07:28 AM
The 911 had 1/2" spacers between the shock dust cover and the lower rubber mount.
Eric_Shea
Feb 22 2011, 11:01 AM
That was for the US ride height. I think I have some (maybe only one?)
my928s4
Feb 22 2011, 11:22 AM
I ended up using two large washers in the location Ron detailed above.
jcd914
Feb 22 2011, 05:56 PM
I installed a lot of these as they were the shop owners preferred shocks. Never had to do anything except on cars with mono ball camber plates. Everything with a stock camber plate and bushing/mount cleared without issue.
A wad of clay or dum dum on top of the shock and closing the hood most of the way, will tell you if it is close. If it is not close try again closing the hood farther. Repeat until you get too close for comfort or close the hood all the way and still have clearance.
Jim
Eric_Shea
Feb 22 2011, 06:16 PM
i was going to say... are you sure you're going to have a problem?
MikeSpraggi
Feb 23 2011, 03:45 AM
QUOTE(Eric_Shea @ Feb 22 2011, 05:16 PM)
Just a smiggin'
Click to view attachmentI'll proabably just go with the 2 washer solution.
crash914
Feb 23 2011, 04:00 AM
Nice paint Mike... I have older Yellows on my car. I will have to go and take a look and see how it was done. Not by me. I am pretty sure that the shocks are not that high though.
Eric_Shea
Feb 23 2011, 08:06 AM
Let me see if I can find a pair.
Eric_Shea
Feb 23 2011, 08:23 AM
RJMII
Feb 23 2011, 10:24 AM
Eric_Shea
Feb 23 2011, 10:26 AM
Stop laughing... pretty sure the pair I found is yours.
McMark
Feb 23 2011, 10:56 AM
You got the dust covers installed on those guys?
my928s4
Feb 23 2011, 11:05 AM
Yikes, that is a lot of thread. Mine looked like this before adding the washers.
SLITS
Feb 23 2011, 11:29 AM
Stock washers are 10 mm (0.396") thick.
I always thought they were there to add weight to the front end of an assdragger so it would almost handle.
jcd914
Feb 23 2011, 12:56 PM
They were added to US cars when the ride height was bumped up to comply with US Headlight height laws. I believe it was mid to late 70s. Pretty much at all the shops I worked at it was routine to toss them anytime the front struts were dropped down on a 911.
Jim
MikeSpraggi
Feb 24 2011, 01:17 AM
QUOTE(McMark @ Feb 23 2011, 09:56 AM)
Dust covers are on but not the original but are like the original. The struts are wider than a "normal" early 911 strut. They take 3.5" calipers but again, are noticeable wider than normal struts. After doing some research just now, I believe these are the Hydropneumatic struts from an early E. They now have Koni yellows in them. Just had to fabricate a custom gland nut (as the nut is much wider than a T or S strut.
I bought them from a well regarded local 914 racer years ago. The part ID on the strut is 90134108410 which says they are Koni struts for 72-73 911 w/ S caliper according to the PET catalog. However.... the struts have BOGE on them and are much wider than a T or S strut of the same vintage.
Eric_Shea
Feb 24 2011, 10:09 AM
Yes, those sound like Hydro struts. There was a kit available for them back in the day to retrofit Koni's. Sounds like that's what you have.
Do you want the washer or should I put them back in the box under the press with the other metal drifts and bits?
MikeSpraggi
Feb 24 2011, 12:17 PM
QUOTE(Eric_Shea @ Feb 24 2011, 09:09 AM)
Eric, the washers will be needed. PM me the detail$. Thanks.
MikeSpraggi
Feb 28 2011, 07:38 PM
Thanks Eric!!! Paypal sent.
whatabout1
Feb 28 2011, 08:05 PM
The yellows in my 73 touched the hood.
Washers were added.
lonewolfe
Sep 9 2012, 04:26 PM
I'm late to this topic but I recently installed Koni Sport Adjustable front struts to my 72' 914 without any clearance issues. I used the same hardware from my original Boge struts. The only issue I had was it was tough getting the nuts on the top of the shocks because there was not a lot of thread. I had replaced the upper strut mounts to poly graphite mounts and that is what I attribute to the clearance issue. I bet if I had left the stock mounts in there would have been a lot more thread sticking out and potentially a clearance issue. I never even thought about a clearance issue till I saw this thread.
mittelmotor
Sep 9 2012, 11:05 PM
This thread made me go out and check for dents in my hood. Thankfully, none. Pheww!
I didn't even think to check for clearance, but not a lot of thread showing above the stock mount.
Eric_Shea
Sep 10 2012, 08:53 AM
I think the issues come into play when you use a later model 911 strut housing and get the specified insert for that housing. Those inserts are spec'd longer in order to deal with the 10mm washers that are stock on those year 911's (am I making sense?)
914_teener
Sep 10 2012, 09:09 AM
QUOTE(Eric_Shea @ Sep 10 2012, 07:53 AM)
I wonder if that is the same issue I saw with the Bilsteins a while back?
SLITS
Sep 10 2012, 01:39 PM
You never make any sense whatsoever!
Eric_Shea
Sep 10 2012, 01:41 PM
Bitter... find me some HE's
Eric_Shea
Sep 10 2012, 01:42 PM
Mint BTW.
balljoint
Sep 10 2012, 02:32 PM
QUOTE(Eric_Shea @ Sep 10 2012, 03:42 PM)
Mint BTW.
Erc, I don't think HE's come in different flavours.
Just trying to save you some disappointment at a later date.
MikeSpraggi
Sep 10 2012, 03:57 PM
Yes, making sense. You described my set up exactly. I think we used washers to get around the issue.
lonewolfe
Sep 10 2012, 09:59 PM
I'm late to this topic but I recently installed Koni Sport Adjustable front struts to my 72' 914 without any clearance issues. I used the same hardware from my original Boge struts. The only issue I had was it was tough getting the nuts on the top of the shocks because there was not a lot of thread. I had replaced the upper strut mounts to poly graphite mounts and that is what I attribute to the clearance issue. I bet if I had left the stock mounts in there would have been a lot more thread sticking out and potentially a clearance issue. I never even thought about a clearance issue till I saw this thread. Now i have to go check how much clearance I have.
Eric_Shea
Sep 11 2012, 08:33 AM
Again...
Sounds like you should be fine.
914Sixer
Sep 11 2012, 07:22 PM
Like Eric said, some of the struts will NEED the spacer, others WON'T depending on the strut year.
lonewolfe
Sep 12 2012, 09:34 PM
I checked and there are no clearance issues on my 1972 914/4.
Tedman5
Sep 14 2012, 07:45 AM
No issues on my 70 with koni top and bottom bushings supplied with struts.
Eric_Shea
Sep 14 2012, 08:16 AM
balljoint
Sep 14 2012, 08:46 AM
QUOTE(Eric_Shea @ Sep 14 2012, 10:16 AM)
I ALSO have no issues with my set up.
