Full Version: cooling fan
surfbus66
Took the pulley off of cooling fan to blast and repaint. Just noticed when blasting that there is a small piece of metal pounded into the pulley. Did the factory do this for balancing? If so, did i screw up by not indexing fan and pulley prior to removal? Thanks for your input.
bam914
Yes. Plus the pulley will no longer be centered to the fan hub.
detoxcowboy
Jake Raby
Re-centering will be a real bitch.. Unless you have access to a balancer or make yourself a centering tool, it won't be happenning. This is critical to dynamic balance and even keeping the alternator belt on the engine.
surfbus66
QUOTE(Jake Raby @ Feb 22 2011, 04:53 PM) *
Is getting it centered more of the issue than where the weight is placed, or do both need to be concidered?
Jake Raby
Both.. If its not centered it can't be balanced. I have seen people remove these and reinstall them only to imbalance the engine 40 grams.
surfbus66
thanks for your help.
