Full Version: ignition switch
pauldunn
My 914 wont crank with the key. i have taken a screwdriver to the starter and it cranks nice, so i know its not the starter or battery. my next step is to test the ignition switch. can anyone give me pointers on how to get to it? my repair manual is no help in this way. does anyone have better wiring schematics than the one in my manual also? if you can help i would appreciate it. thanks
Mike Bellis
It's the fat yellow wire behind the switch. It also goes to the seat belt relay under the passenger seat befor it gets to the starter. check there too. You can bypass the relay with a paper clip for testing by connecting the two yellow wires. If you use a teast light behind the switch on the yellow wire. You should see it light up if the switch is good. If no light, you need a new ignition.
Black22
QUOTE(kg6dxn @ Feb 23 2011, 03:20 PM) *
Cap'n Krusty
QUOTE(pauldunn @ Feb 23 2011, 03:15 PM) *
What year is your car? You'll never get anything but WAGs until we know that. Good schematics at Pelican Parts' website.
The Cap'n
pauldunn
piratenanner.gif piratenanner.gif piratenanner.gif My 914 is a '72. What is a WAG? Does anyone have the ignition circuit schematic? Ive got the schematic for the entire care but thats a lot of lines to trace. to have schematics of the individual circuits would make things alot easier.
Black22
QUOTE(pauldunn @ Feb 23 2011, 04:46 PM) *
piratenanner.gif piratenanner.gif piratenanner.gif What is a WAG?
IDK...my guess is a "wild ass guess"...am I right?
Hijack over!
pauldunn
QUOTE(Kirmizi @ Feb 23 2011, 06:29 PM) *
Thanks mike, those links were huge helps.
