Look on the driver side front door jamb for the Chassis plate, & the number stamped in the bottom box will be the color code, which you can look up in the 914 info section at the top of the page, & at p914.com for sample cars in the color.
If the repaint after the 73 clip was added to the original 72, then that "silver/blue" is possibly the OE Marathon Blue metallic L96M - if not some other aftermarket similar color close to that look.
FYI - you can also use the top number on that Karmann plate in the L-F door jamb to decipher which week in 71 or 72 yours was built by using the year stamped on the VIN sticker on the rear door jamb - assuming that plate wasn't changed with the 73 clip. If it was, then use the Chassis no. stamped in the rear floor of the back trunk. Similarly, you can get the 73 VIN for the front clip on the stamping on top of the pass/R wheel well inside the F trunk. Maybe then you could get 2 COAs from PCNA!
BTW - unless you like the footrest on the pass. side, your 72 has an adjustable pass seat & doesn't need it - so you could sell it off to someone on here with a 70-71 MY 914 or 914-6 that needs one, and make back at least part of your evil-bay fee!
As a Trojan I won't say "Go Aggies", but Cheers!
Tom
