I'm looking for the following:
- the total height of a rear wheel hub, from rotor mounting face to the axle-side face (basically, from stem to stern)
- the height of a rear wheel hub from the rotor mount face to the bearing interface (basically, how far the wheel hub extends out from the wheel bearing)
- the length of the splined section inside the wheel hub
- the distance from the axle end of the hub to where the splines start
- the length of an axle stub from the wheel bearing face to the tip of where the axle nut threads on
