Full Version: Rimco has moved
76-914
Just spoke with Todd at Rimco and found that they are in the middle of a move. This is why things are taking a little longer, now. They should be in full swing by Monday. piratenanner.gif My case is std; needs no line bore and crank can be polished to std. hot dog beerchug.gif
EDIT: Their new # 562.946.3100
Cap'n Krusty
Standard cases and cranks are still pretty common for T4 engines. The big problem is the deck (sometimes called the cylinder spigots). They collapse in the center, making a good seal at both the case end of the cylinders and at the heads nearly impossible.
The Cap'n
Krieger
What city are they in now?
Jake Raby
That sucks.. That old location was historic for the ACVW industry. Sad..
silver74insocal
76-914
QUOTE(Cap'n Krusty @ Feb 25 2011, 01:35 PM) *
The Cap'n
And if it is then it is stromberg.gif ? Or is there an alternative?
sean_v8_914
Adrian in vista, headflow masters
Don at bugpatch in santee
