Update: had trottle body taken out, cleaned new gasket, and went 1 notch richer. Now I'm at 950 warm idle no surging!!! Hope it holds. I think I will leave alone for now but I would love to test another MPS just to see if there is a change. I put this one in when I bought the car . Old one was shot. Got this from injector corp. It is a rebuild I believe. If any one has a spare. For 75 2.0 d-jet. , its the only thing I have not tried yet.
Phil
quote name='saigon71' date='Mar 1 2011, 09:47 PM' post='1438731']
[quote name='Philip W.' post='1438394' date='Mar 1 2011, 08:59 AM']
[quote name='saigon71' post='1438385' date='Mar 1 2011, 08:10 AM']
[quote name='Philip W.' post='1438294' date='Feb 28 2011, 11:42 PM']
Should the idle adjust screw on the throttle body completely stop the flow of air into the throttle body? When mine is in as far as it can go, idle will not go below 1200 rpm, but with aircleaner removed, if with my finger I stop that hole from the inside, the idle immediately drops andholds steady at @800 rpm. Smooth and no surge. Seems like it should close off the air flow more. Consider that valves are set, timing set, and dwell and points are right on, as is the t.p.s.(throttle valve switch. Also injector seals, intake runner seals have been checked for leaks, new vaccuum hose kit installed. No leak detected from throttle body but I was going to pull that tomorrow and replace anyway. Also butterfly valve does not stick. Aar good.
Anything else that needs checking? Or is it the idle adj screw?
Thanks
Phil
P.s. it is a 75 2.0 d-jet.
[/quote]
Phil:
I am no expert, but it sounds like you are running lean at idle. With the air cleaner on and everything in place, try using the idle mixture adjustment knob on the ecu. Turn it one click at a time, clockwise (to richen the mixture) and allow the engine to stabilize. Then mess with the idle adj screw.
I have a 74 2.0 D-jet and had similar issues (I could not get the car to idle below 1300 RPM or so with idle adj screwed all the way in). I went back and double checked EVERYTHING tune-up and vacuum related and found something else off. After fixing, I was able to get the idle to 900 RPM using the idle adj screw by adjusting the ECU mixture.
I am sure some of the djet gurus will chime in as well.
Good luck.
[/quote]
thanks, so what was "it" that you found that was off when you went back and re-checked? we (myself and my porsche mechanic) went back to the fuel mixture increase the richness setting at the ecu, but did not seem to correct the problem, so must be missing something.
[/quote]
"It" was the timing and a mis-routed vacuum hose for me. It looks like you have those bases covered though. I used this diagram to double check the routing:
http://www.pelicanparts.com/914/technical_...4_20FI_diag.htm[/quote]
