QUOTE(euro911 @ Mar 1 2011, 04:43 PM)
I'm no expert by any means, but I thought the defrost wiring was imbedded in the plastic sandwiched between the two sheets of glass, and one would just need to find a good replacement glass ...
Don't know how you'd get at the wiring to 'fix' it - but it
would be interesting to see it happen, if its possible
Like the early 911 rear windows, the defrost lines are embossed on the outside surface on the inside of the window, not sandwiched in between the two glass panels. I wish they were! They get worn off with regular wear over the years. My window has the OEM lines but they are scratched/worn through in some areas. They are metallic so they do rust also.
Greg
