1974 Porsche 914 2.0 Limited Edition, black with yellow trim.
VIN# 47429149xx. Clear title.
Price $15,000
Restoration project 1997 to 2001. Garage kept since 1997. It has only been in the rain 2-3 times when caught out on a drive. Owned and restored by 25 year PCA member. Restored to very original condition.
Body: Car disassembled, rust spots were found in outer longitudinal panels behind rocker panels. These spots were cut out and repaired with 11 gauge sheet metal, which was continuously MIG welded around the perimeter of the new metal.
Repair of a few rusty spots in rear of floor pan were repaired using the same materials and methods. The battery support & tray replaced with new parts. Chassis stiffening kit installed at rear suspension area.
Repainted with Sikkens paint, jet black & saturn yellow to match original colors. Base coat, clearcoat system with OEM yellow negative stripe applied prior to clearcoat.
Full set of original factory Mahle alloy limited edition wheels. Full set of 205/55x15 Kuhmo Ecsta tires. Spare has never been on the ground. Front tires, tread 50% (worn on inside due to suspension set up with negative camber), rear tires 80%. Factory jack & tool kit. Factory Sway bars. Brake calipers rebuilt and rotors replaced. New19 mm master cylinder. Pedal cluster rebuilt with bronze bushings, new accelerator pedal. Fuel pump & filter relocated to front trunk, all new fuel and vacuum hoses using OEM Porsche hose and Stainless Steel tubing.
New rubber seals for body & doors. New bumper tops front & rear. New bumper over riders front & rear. Bumpers and fog light grills painted Saturn yellow. 914 & 2.0 emblems painted Saturn yellow. Porsche crest on hood.
New European front lenses and taillight lenses. Factory fog lights. Limited edition front valence.
Drivetrain: 2.0 liter engine, fuel injection, new bearings, oil pump, heads re-worked with new valves & guides, new fuel injectors, Euro Pistons & cylinders, flywheel surfaced, new clutch, pressure plate and throw out bearing. All seals & gaskets replaced, silicon valve cover gaskets. Distributor re-bushed, new F.I. trigger points, Hall effect sensor installed to replace points & condensor. Alternator rebuilt. New distributor cap & wires, factory RPM limiting rotor. 2.0 liter SSI stainless steel heat exchangers and new factory 2 liter muffler. 5 speed side shift transmission rebuilt, new bearings & synchros. New bushings in shifter mechanism.
Interior: New carpet, excellent original factory dash, no cracks. Center console with gauges (volt, oil temp, clock). Intermittent wiper option and electric washer pump (914-6). Oil pressure gauge added to left gauge replacing the large red light at top of gauge. Dual oil pressure sending unit to retain oil pressure warning light. The seats are in excellent condition, no tears , early style non-pleated inserts. Original pleated seats go with car but need to be recovered. New windshield. Right hand mirror.
Restoration was completed in 2001.
Car has been driven approximately 6,500 miles over past 10 years since restoration. Paint still very nice but there are a few minor scratches. Odometer showed 69,014 miles when I purchased the car but it was not working. Odometer was repaired and now shows approximately 75,600 miles but actual mileage is not correct because I do not know how many miles the car was driven with broken odometer prior to my purchase. Speedometer registers approx 10 mph fast due to lower profile tires currently installed on car.
Needs: Rear Targa top seal is worn. Small split in back pad near seat belts on both sides (see photos). One small dent in quarter panel above left tail light (see photo), good candidate for paint-less dent removal.
Valve adjustment, tune up, oil & filter change, new battery in Feb 2011. Car had been sitting in garage previous 2 years. Started up and driven 250 miles 2/20/11. Runs excellent. 30 MPG. I have enjoyed this 914 for years and have owned Porsches since 1980. Work now requires more travel and interests have changed. Time to find it a good home.
(contact information of friend posting ad)
Email: mfetter@comcast.net
Phone: 423-364-5009
Mark (owner) can be reached at 423-304-2319 but his cell phone doesn't work at home, and it's hard for him to take calls during the day.
Link to all photos:
http://s46.photobucket.com/albums/f104/wera910/MarkDs/
