yeahmag
Mar 3 2011, 04:15 PM
Well, in my never ending quest for dirt cheap wider wheels I wrote my yearly email to Diamond Racing Wheels. They still aren't doing the offsets we need, but they were prompt and very nice.
Aaron,
The maximum back space we make in the 15x7 4x130 is 4" or zero offset
because the center is dished backward like a regular RWD wheel.
Sorry but I don't think we will be able to help you.
Bill
On Wed, Mar 2, 2011 at 11:36 PM, Aaron McKinnon <mckinnon@caltech.edu> wrote:
> > I'm after a 15" rim, 7" wide, 4x130 bolt patter, 4-7/8" back spacing. I
> > could always add spacers if you can only do 5" back spacing. This is for a
> > narrow bodied Porsche 914 on DOT-R's in autocross. Car was the PCA CP class
> > winner last year and I'd like to take it up a notch.
> > Let me know.
> > Thanks.
> > -Aaron
strawman
Mar 3 2011, 04:27 PM
Diamond Racing wheels are heavy. We've got a set for our 24 Hours of Lemons Opel GT car in 15x7... they as tough as iron and every bit as heavy!
rick 918-S
Mar 3 2011, 06:43 PM
Got a photo?
I find it hard to believe that there isn't enough space on the barrel to slide the center out an inch.
Here's what I would do. Buy a set, grind the welds off the back of the center, build a jig to fix the center where I wanted it and reweld the center. There just steel wheels. I've done it before.
Sorry it was pre-internet and I have no photos.
Edit: I think I may have had to turn the wheel around, weld up the valve stem hole and re-drill the stem hole on the new outer side of the wheel.
yeahmag
Mar 3 2011, 07:02 PM
I've got a set of stock 914 steelies I plan on doing this to if I can ever find wider hoops.
rick 918-S
Mar 3 2011, 07:32 PM
QUOTE(yeahmag @ Mar 3 2011, 07:02 PM)
Back in the day (late 80's/Early 90's) we used to be able to purchase steel barrels with the centers unwelded. The local dirt track stock car guys had a source for these. I think I got a set once with wide 5 for VW. We built a wide body Ghia with VW headlights and used these wheels. I would check with the Dunebuggy shops to see if they have a source for these wide barrels with weld in centers. They will be for off road use.
