I am working on cleaning up and installing the fresh air inlet box into my project car. As you might know, the drain tube and connectors are either NLA or hard to get. I went to the local hardware type store and bought some 5/8"ID/7/8"OD dishwasher drain hose and went to FLAPS and bought an elbow, Tee, and connector (DOH, need 2 ). The hose is very pliable and might be prone to crimp but it's a suggestion for a relatively easy substitution.
Click to view attachmentPO didn't remove box when car was repainted (scottyb did, though)
connectors are tight fit, so tight, I can't remove the Tee for the pic. I'll use the connector(s) between the outlets on the box and the hose. A few wraps of vinyl tape should hold and be minimally noticed. The substitute hose will easily handle the water flow out the box (not that the car will be caught out in the rain )
not CW but these parts are NLA
connection to box is not final fit but this is the idea
final fitment before taping
hose - $8.99 fittings ~$15
