I was installing the rockers on a GA case 2.0 and had an adjustment screw and lock nut fail. I'm sure their stretched and will not allow fine adjustment. I had a heck of a time removing the screw from the rocker.
I checked the adjustment screw with a thread chaser for size. It appears the screw is an 8mm X 1. I went to the Pelican site to price check these and noticed they show the rocker screw as 10mm for the 73 and up 2.0. Did someone at one time install 1.7 rockers on this 2.0?
Any issues with using these on a stock engine?
The heads are 2.0 with three intake studs.
Is the ratio the same?
If there is, anyone have a full set of rockers?
