QUOTE(Valy @ Mar 12 2011, 09:30 PM)
I need to fix the fan in the airbox. It stopped working.
Can I remove it somehow without pulling the fuel tank?
No, and putting the airbox back in after the repair is a PITA. Don't omit the rubber seal around the top, where the box meets the cowl. You may find it easier to fashion a bracket to help with the reinstallation of the airbox, because it's hard to fit back into place. Some leverage helps. Takes lots of muscle and patience.
Are you sure it's the fan? The slide switch on the dash is a common source of trouble. Make sure theere is power to and from that switch.
Good luck.
