timofly
Mar 12 2011, 08:48 PM
Does anyone have a source for the hoses running from the fresh air box to the dash outlets? They are a bit less than 2" ID.
914Sixer
Mar 13 2011, 06:54 AM
I have some used ones that are faded but in good shape.
rwilner
Mar 13 2011, 09:26 AM
if you don't care about CW, look on mcmaster carr for BLO-R-VAC hose, part # 53335K12. It has a 60mm id and is temp rated. It's what I used
euro911
Mar 14 2011, 11:41 AM
I happened to see some at a local aftermarket VW parts house (IPC) out here and they were fairly inexpensive ... $2.00 ~ $4.00 ea. (black paper outsides with silver foil insides) ...
Click to view attachmentGot an IPC, J-Bugs (or equivlent) store close to you?
detoxcowboy
Mar 15 2011, 12:39 AM
Pelican parts has all the hoses all the sizes and german but you have to look under all porsche, some you will have to cut to length but they are not expensive and german quality (Paper Aluminum Paper, not vinyl Washer Machine Drain or Dryer Vent Duct styles) compared to the after market guees repro crap..
