QUOTE(jimkelly @ Mar 13 2011, 01:29 PM)
my plan for today was to remove the starter ( done ) and the whole ignition MODULE and just get a replacement on ebay. i am not sure what is bad but when i turn the key the lights come on on the dash but the starter does nothing, maybe makes a slight small thud/click. the cars was acting weird for a few starts and then nothing. i though maybe it was the ignition switch because my son - who is learning to drive - has a habit of turning the keyTHE WRONG WAY when trying to start the car sometimes, and that is when the problem first occured.
thanks
jim
QUOTE(phatnine11 @ Mar 13 2011, 01:22 PM)
Jim,
Are you trying to remove the tumbler assembly or the ignition switch?
Phatnine11
Jim,
If memory serves me right, the white part with the two screws is the actual ignition switch. If you remove it from the assembly, you should see a "slot" that you can use a screw driver on as a key. This way, you don't have to install the entire unit while you are testing and if the switch is bad, you don't have to remove the tumbler assembly and re-key, just replace the switch. I would check for voltage on the solenoid wire at the starter and work my way back to the switch.
