Whats the difference between a 2366cc motor built with a bore of 103 and stroke of 71mm and a 2387cc built with 94 / 86mm.
if you could build a larger motor with smaller pistons, wouldnt that make the motor last longer?
Do you lose power by using smaller pistons?
If so, how much? If not, why not just build the largest motor with the smallest pistons - example 94/90
