QUOTE(ppetion @ Mar 13 2011, 07:43 PM)
keep in mind that it is the oil temperature.. and as soon as i made a stop, it goes down less than half. the engine runs great the whole time... the flaps were removed.
the flaps were removed???
DANGER WILL ROBINSON, DANGER!
I think we may have found one reason why your temps might read high. The flaps are supposed to be present to control the air flow through the cooling tin. If you remove the one on the right side of the motor, you remove the duct that forces air down through the cooler. This is a VERY VERY BAD IDEA.
Find some cooling flaps and install them. If you can, hook them up correctly to a thermostat! If you can't do that, at least fix them in the "maximum cooling" position.
--DD
