I've taken bits of it out with a hammer and screwdriver....
You can unscrew the mirror and its arm from the base; there is a long slot-headed screw up inside the arm that holds it to the base on the windshield. Once it's on the bench, you can do anything to it you like. Including locating a replacement mirror to install in its place. Like I did, after removing bits of the old mirror...
--DD
