I am in the process of converting to retractable seat belts and ran into a small snag.
My car car is a 72 so the "buckets" were already in place for the new retractor, however I can't figure out what bolt size goes into the firewall? There was a bolt in the parts stash that came with the kit that is close, but seems to cut new threads if I push it. I tried one of the existing bolts and same thing.
I did a search and found out the bolts at the top and bottom are M11x1.25, should this also be the same for the firewall?
It could just be overspray/gunk clogging up that hole since it has never been used, but wanted to check first.
Thanks guys!
