minnesota loon
Mar 20 2011, 03:23 PM
Any help with how to install dual oil pressure sender.... Is there an extension kit still available? grease gun hose? connectors? Any one.........
VaccaRabite
Mar 20 2011, 04:08 PM
Grease gun hose and joins from Home Depot is how I did it.
Zach
Dave_Darling
Mar 20 2011, 04:23 PM
Grease gun hose, adaptor piece (you can probably make one out of brass plumbing supplies) and a bracket to hold the sender somewhere. Make sure you ground the case of the sender, or you will get no readings or incorrect ones.
--DD
minnesota loon
Mar 21 2011, 12:17 PM
Thanks for the help photo shows me what i need to do.
thanks again
underthetire
Mar 21 2011, 12:50 PM
I used a grease gun hose, and a 1 piece conduit clamp from the electrical section.
tradisrad
Mar 21 2011, 02:13 PM
mine is a VDO, comes with a bracket
here is an example
Mar 21 2011, 02:28 PM
QUOTE(tradisrad @ Mar 21 2011, 01:13 PM)
here is an example That's the one i used too, came with a extension hose and a clamp ...
minnesota loon
Mar 21 2011, 05:08 PM
Are the threads on the sender npt? or metric? And what are the threads on the engine? or is the vdo kit any where to be found?
zambezi
Mar 21 2011, 08:59 PM
QUOTE(minnesota loon @ Mar 21 2011, 06:08 PM)
should be 1/8" NPT
