Need some insperation, pulled all the tin to paint it and pollished the intakes.
What are some extreme things people have done to really make it look good inside the engine compartment.
the carbs sit so far apart and with the stock cooling system it looks just like a massive hole in the car like something is missing.
Just spitballing here but I was thinking of making a sheetmetal cover that attached between the air cleaners and carbs that ran between the two covering the top of the engine, with a central mounted oilcooler with fan on the back ducted out the wheel well. (will add sketch later). I figured due to the roof line and the lack of a rain tray. air would pass over the oil cooler and be pulled by the fan and ducted out of the eninge compartment via the wheel wells. Also this should help to duct air to the front of the engine towards the cooling system instead of just down on top of the engine.
I am sure there is a massive flaw in this plan I am not seeing so please let me know.
