McMark
Mar 21 2011, 06:05 PM
I dislike AN style hoses and I'm interested in being able to make my own crimped end hose connections. Seems like rather than building these assembled AN hoses, I could make my own custom hoses. I expect that there's a wider range of hose ends available for crimping than there are AN fittings. Seems like I'm often spending hours searching for just the right AN fitting, since I also hate adapters. Anyone have any experience with this?
These are the types of hose ends I'm thinking of.
As far as I can tell,
this type of crimping tool should work.
Anyone have a good source for compatible hose ends? I'm thinking banjo fittings, etc.
JeffBowlsby
Mar 21 2011, 06:22 PM
How about these kind of crimps Mark?
http://www.mcmaster.com/#crimp-hose-clamps/=bjajpqM-C has a a lot of different kinds and tool available.
McMark
Mar 21 2011, 06:26 PM
I have that setup and like it quite well. But I'm looking for something to supplement that setup. I'm looking for OE-Porsche looking hoses. Like these...
JeffBowlsby
Mar 21 2011, 06:31 PM
Those look like these then:
http://www.mcmaster.com/#hose-crimps/=bjand6Search on 'crimp hose' at M-C. Lots of options, should get you close anyways.
Cap'n Krusty
Mar 21 2011, 06:36 PM
When the late Dave Shepard had GPR, he made hoses for us all the time. Sometime between his passing and the initial inventory, the tooling and parts grew little legs and departed for parts unknown. You'll have to source a metric kit, because (according to out local hose and coupling place) there aren't any inch sleeves that fit metric hoses.
The Cap'n
Mike Bellis
Mar 21 2011, 07:11 PM
There is a shop called Source in Pacheco/Martinez that is a great resource for odd ball hoses. Including metric fittings. He makes hoses and hardlines. He also sells hose parts and fittings.
sixnotfour
Mar 22 2011, 04:13 AM
For the german Cohline stuff ,they sell a manual crimper, If that AC crimper will be stout enough to crimp the steel sleeves, Its cheap enough to try, the Cohline one is 1K.
I modified an old dayco hydraulic crimper to do the cohline stuff, basically have to rebore and shorten the crimp length, it does a crimp like your picture.
rebel racing will crimp em also, not sure what crimper he uses,
I have this one, and so does gunnar restoration.
