QUOTE(r_towle @ Mar 28 2011, 03:06 PM)
QUOTE(Richard Casto @ Mar 28 2011, 02:55 PM)
Anyone want to guess as to what body part might be used to interface with the hanger from those overhead cranes?
Richard
I thought that was what the donuts were for...factory assembly dollies and such.
rear donuts can support all the rear, they are under the longs.
Fronts can handle the front...it weighs alot less, especially once you put a motor in place.
RIch
That is my thought exactly.
On top of that, as far as I can tell, I don't see evidence that the drive train is installed in those photos. So my hypothesis is that the donuts are only intended for production line lift only. And that maybe when they marry the body to the drivetrain, that they lower the body onto the drivetrain rather than lift the drivetrain up? If that assumption is true then maybe in the assembly line they never suspended an entire complete car via the donut holes? My point (using a lot of "this might be true" logic) is that this all might be more evidence that you should not use the donut holes as lift points for a complete car (which is not a new idea by any stretch).
(Quick edit after I just read what I had typed. I think what I am trying to say is that you an lift that car if the weight is distributed across all four donuts, but I don't think it's a good idea to try to jack up the car using just a single donut. Especially one of the front ones only)
Richard
