Click to view attachmentClick to view attachmentHi All,
Following the original posting on replacing the UPPER bearing in the steering column
of 914-4 (I have (2) 1973's) I ordered from Pelican Parts. Today the parts arrived and they were WRONG!!
On the site page under "Steering Shaft Parts" there is a photo of the correct bearing with the white plastic center insert with P/N 928-347-739-02-M737: THIS IS WRONG!!! I ended up getting the sheet metal sleeves from the listing above.
To get the RIGHT BEARING PART, go farther down the page, to the next box section and you will see a photo of the RIGHT PART with P/N 911-347-771-02-M100
More good news, it's much more expensive at $37.00 instead of the $9.50 shown above!
The Pelican folks are working to fix this error, but with the right P/N you should be saved the wasted time & $$ I experienced.
I'm attaching a photo of the correct part, blow it up to view.
Best of luck,
Terry
