ALL PRICES INCLUDE SHIPPING:
Ashtrays, $12
Sideshift shifter, $35
Rubber shift boot, $10
Early Seat belt set, rusty mounts, but useable, $25
Steering column assemblies w/key, one '71, one '73, one 74, your choice, $75
Sail panel trim, side pieces, some scratches but useable, $40
Plastic plugs for front sheet metal, about 10, $8
Front bumper top, two studs replaced, a bit dimply but surface is VG, $125
Targa tops, one from a '71, one from a '73, no front latches, $90
Late window regulators, D & P, $30 each
Early P side window regulator, $30
Rear windows, non heated, $55
Lower dash pads, late, $50
Brake proportioning valve, cleaned and repainted, $20
Fuel level sender, w/gasket, checked good, $60
Headlight switch, $50
Foglight switch $40
Emergency flasher switch, $40
Cigarette lighter, including socket, $20
Rain tray, all mounting holes intact, small repaired crack on interior, almost invisible, $65
Starter motor, cranks good, cleaned and painted, $50
1.8 Flywheel, clutch and pressure plate, used but useable, $90
Black interior trim pieces, name your piece, $12
Parts added:[b]
Rain trays, all mounting holes are crack-free, small <1" crack on interior has been repaired with epoxy and is almost invisible. $65, shipped. Drain tubes are crack-free, take them with a rain tray for $15, $25 on their own.
2.0 Distributor with new points and wires, cap looks new, but not sure. 039 905 205 BA. $110 shipped.
Relay board cover. Yes, it's been cracked like 90% of them but I've been rehabbing them by bonding aluminum washers to both sides of the bolt hole. Looks factory and stronger than original. $18 shipped.
Steering racks, they're tight. $100 shipped
