QUOTE(Dave_Darling @ Apr 4 2011, 01:11 AM)
Looks like a 2.0, yes?
The red wire is about 90% likely to be the wire from the Aux Air Regulator. It hooks up to a white wire that gets power when the fuel pump is running.
There's a good chance that the white wire you are showing is supposed to connect to that as well. There's a higher probability that it goes to the thermo-switch, which sits up off the top of the crankcase but below the air cleaner on the right side.
--DD
Yes Dave later model 2.0. 75 IIRC and yes, the TTS has a red wire connected to it from the AAR from the looks of the harness on the engine I have here. Irv, the TTS is bolted to the top of the block. I tried to take photos of the connection the the engine is covered in gunk and vacum hoses. I can't tell but the white wire may aslo be connected there. I think we have wire diagrams on the site someplace. Or Pelican may have them.
