On a 76 2.0 D-jet, FI harness just replaced.
What I have done/checked.
* all FI harness connections
* Power to coil to make sure I was getting power to engine compartment
* disconnected FI harness from relay board and did Sir Andy's carb connection set up
* took out the tank a tested the pump by attaching it to anorher battery....Worked
So is it the relay(s) or should I also check something else?
Thanks Irv
