QUOTE(Cap'n Krusty @ Apr 8 2011, 11:04 AM)
They'll bolt in. I suggest, in your application, you put a large, thick, washer above the mount. Probably about 3" in diameter so you're protected should the mount fail. Something along the line of the one used above the tranny mount or the early engine mount. I might even use the stock washers from a 911 application. Had I done the install, I would have tried to isolate the cross bar from the engine with some Volvo style mounts.
The Cap'n
Ah yes, I knew there was an issue with the transaxle end. Thanks Cap'n. I forgot you need to protect the car if the mount rubber fails. A large washer will save the transaxle from dropping on the ground if the mounts rip out. Anyone else ever have that happen?
It's crazy dangerous and really scary when every rotation of the axle picks up the rear of the transaxle then slaps it back down while you try to who that bucker down!
I have solid mounts front and rear myself. I like them. I have about 15000 miles or so with them and have no issues except better shifting and a positive launch when you blip the loud peddle.
