QUOTE(pktzygt @ Apr 9 2011, 02:01 AM)
QUOTE(TC 914-8 @ Apr 9 2011, 01:05 AM)
before priming, I used some stuff my father-in-law gave me. Looks like milk of magnesia, turned the metal, rust and anything it touched purple. Then primer it, then paint. Never had a problem in that area since.
Any auto parts or welding shop should know what I'm talking about. I'm too lazy to go to the garage to see if I have any left or the name of it.
good luck
T
I think Mar-Hyde is the brand you're trying to think of. There are alot of rust converters out there, but there needs to be rust to stick to. If you remove every last bit of rust, just prime.
They need rust to stick to because they aren't any good.
In my experience the typical FLAPs " converters " are complete crap. Get the metal bare, blasting prefferably then find a buddy that has some Ospho, or if you have more rust work to do go buy a gallon for your self. A little goes a long way. Spray the area with the ospho then treat as directed on the bottle. It needs to set up then get a wash to neutralize the acid. That can then be primed and painted, all by spray bomb if you desire. If you can't find actual OSPHO, there are sevral other companies that make a similar product. I know, and have also used, one made by Purple Power. The main ting you want is for the main ingredient to be phosphoric acid. The cheapo FLAP crap typically has,little to no Phsophoric in them.
Be very careful with OSPHO as it is an acid. This is why it is effective, as an acid it actually etches into the bare metal and creates a real bond and protective barrier. Use it with good ventilation !! The other thing I like about OSPHO is that it is as thin as water and can be sprayed very easily into the longs and other hard to reach areas.
