Fired up "222" today after another extensive check to be sure everything was right.
Pressure lubed the bearings (2 quarts) then drained the excess.
She fired right up and immediately had 80psi of oil pressure.
Fuel pressure went right to 70psi, which is right.
Only thing that didn't work is the TAC.
In my car there is a yellow wire coming out of the Mallory CDI which goes to the TAC to provide the signal. I check continuity again and it confirms.
The other wire on the TAC is a ground which has continuity to the chassis.
So where do the wires go, i.e., ground and signal? Or maybe I'm missing a wire??
Here is a picture of the back of the TAC with the three posts labeled 1,2 & 3.
