QUOTE(falconfp2001 @ Apr 10 2011, 02:54 PM)
I am missing the solid mounts for my side shift conversion. They go on the ends of the bar and fasten to the frame.
Will pay pal for a reasonable price by Wednesday
Thanks
You can make those out of two pieces of angle iron, cut to length and drilled. I made one when I came up short after a long rebuild. The missing one just turned up, so I took the sub out yesterday.
I say two pieces of angle iron, that means two per side, doubled up on the bottom to make a channel like the original. If you use 1/8" thick angle, about 1" by 1" works, and is actually stronger than the original. The sides being taller made it harder to put the nut on the bolt, that's the only drawback I noticed.
